What FPV system for Hero3 live preview?
BennyS said:
Ok... I try that, but i still don't get the playback feature icon to come up even plugged into the wireless transmitter. Also, I purchased some DJI clover leaf antennas, can I replace the stock antennas on the monitor with the tx AND rx antennas?
No, but you can use one of the cloverleafs and one of the stock antennae...though that likely won't give you much better range/performance than just the new one by itself. The Diversity mode displays the feed from whichever of the two are getting the better signal at the moment.
Ok... so what is the difference between A,B,C, and D? Groups? also. U mentioned little switches my screen may have, It has none and the options just have your normal bright, contrast and such nothing else.
No idea, where do you see those referenced? After looking at some of the info on that monitor, it seems that channel selection is handled just by using the "search" button, and it will scan to find the correct one. I believe the connection between your Tx and Rx is ok, I just think the Tx isn't getting any signal from your gopro.
I plugged in the go pro to my tv and the video playback icon came up.... There was not on or off for it.... Ill play with it again tonight... Maybe its a bad cord or something from the go pro to the wireless transmitter. Ill post videos of everything tonight so you can see what I have done.
Below you will find a video of my setup as well as a run through of what I am doing....
http://youtu.be/h431LHigEJs
brianklenhart
