Weak Image Transmission (P4A+)
How are you all finding the range and live view stability on the P4A+ and I guess the PRO?
I conducted the first test flights earlier and although the drone is handling well I'm getting some image transmission warnings and general low signal at places my old P3A would have a rock solid link.
To be fair a couple of the areas I tested at might have been down to 2.4g wifi interference but I did do one run to 1.5KM over the coast and I did get one warning message but moving away from my car and re-positioning the controller antennas seemed to lock everything back in.
Airdata UAV flight log analysis is not showing up anything out of the ordinary and minor signal errors are at comparable levels to my old Phantom 3.
So can I generally expect a bit less range on the P4A? Is it a bit more fussy with regards to antenna placement?
Side note, VERY impressed with the camera. I fired off a few test shots in auto and was well impressed with the IQ.
