- Joined
- Mar 10, 2016
- Messages
- 224
- Reaction score
- 29
- Age
- 56
Will it still hover using gps signal and vps off? That was my biggest question . Thanks ahead!can cause issues and unstable flight trying to free hover and land over water. The texture of the waste and the rolling nature don't work well with the ultrasonic sensors.
Had I done that with my first P2V+, it might not be in the bottom of a lake.Why not test the floats? Take the floats off the Phantom, tie them together and start adding weight to them in water. You could use 1/2" drive sockets to incrementally add weight. Weigh the Phantom and compare the actual weight the key-bobs will float. I think the Phantom weighs about 2.8lbs, so if the key-bobs will hold 2.8lbs of 1/2 sockets, you're good. However, I'm not sure it will save a Phantom if it gets totally soaked. Recovery may not accomplish much unless you have insurance (which isn't a bad idea if you fly water much).
Nice idea though, inexpensive! Let us know how viable it is if you validate the concept.
Don't forget Kite surfers and speed boats pulling parasailers!It would be ok to fly over water if you take care of following:
1. Look for the birds around
2. Your flying start direction should preferably against the wind for long distance flying
4. Have enough battery charge for safe return
4. Turn VPS off
5. You may need hand catch during landing
6. Flying over water will get you long range experience but flying near the beach and over people is not advisable.
7. Be careful, you might spot low flying helicopters too.
Perfect!Don't forget Kite surfers and speed boats pulling parasailers!
Easy to get tangled in their lines, resulting in Blackhawk down!![]()
I need to add Inspire 1's to that list!Perfect!
Just a word from bad experience. Don't let the batteries get down too far. I let this happen on mine and it got very close to the water before I gave it enough power to recover. The prop wash splased a drop or two onto the gimble motors and a trip to Hong Kong ensued.Had my P3 Advanced for around 2wks now. Pretty comfortable flying on land, and have had around 10 trouble free flights (thankfully). I would love to take it to the beach and and out over the ocean (roughly 300 distance)
Is there anyways to over come the nerves of taking it out over water? I know that at the end of the day it is no different to flying over land, but there is always that worrying thought that something could go wrong, and sink to the bottom of the ocean (same could happen on land but you would in most cases be able to retrieve)
Any confidence boosters/tips would be greatly appreciated!
Agreed.My trip out to sea. I'm of the opinion that a crash from altitude over land or in the water will most likely be a total loss in either case.
Oddly, it isn't reflected in the DJI Go app. On the late afternoon I flew, the gliderport was not active though there was at least one RC glider being flown from the north side of the gliderport.Agreed.Isn't that Gliderport in a NFZ?
Indeed. It's not like you can't see when a gliderport is closed or they have all landed for the day, after sunset. Just like a Sports Stadium when it's closed. No harm, no foul!Oddly, it isn't reflected in the DJI Go app. On the late afternoon I flew, the gliderport was not active though there was at least one RC glider being flown from the north side of the gliderport.
spectacular!!!!My trip out to sea. I'm of the opinion that a crash from altitude over land or in the water will most likely be a total loss in either case.
What firmware were you on? Did you top the battery off before flight? Is there any chance that the battery was in a discharge state, based upon your battery storage settings?Miller is absolutely right, don't immediately fly out over water, give your bird a chance to hover a bit to make sure all is in working order. A short amount of flying over dry land then proceed carefully on your journey over water. As many of you have read, I lost my P3P nearly 3 weeks ago after only seconds after taking off. If I was to blame for anything, it was the fact that I immediately pushed on throttle and failure occurred in first few seconds unfortunately, I was already over water. Had I given it a chance to "warm up" a bit by hovering and ensuring all was functioning properly, it might have saved my bird albeit with considerably less damage. Fortunately, DJI stepped up to the plate and is in the process of sending me a new one. They never asked to see or request that I return my P3P, they accepted my flight log and explanation of loss as complete evidence.
Nearly all of my flying is over a fresh water lake and most is above 150ft altitude. If your Phantom was to drop from the sky at that altitude, it doesn't matter whether you're over water or dry land, you're likely facing a total loss regardless of what you hit.
Battery was recently charged and FW was the latest.What firmware were you on? Did you top the battery off before flight? Is there any chance that the battery was in a discharge state, based upon your battery storage settings?
Recently as in the same day? So is the battery shutoff in flight still happening despite all the changes? What exactly happened?Battery was recently charged and FW was the latest.
