Walkie Talkie(2-way radio) cause issues with remote control ?
Will walkie talkie(2-way radio) cause issues with remote control ?
I just had my drone crash and I was using a walkie talkie.
It was not responding property and kept going off to one side then it quickly flew away from me all together. I turn off the remote expecting it to return but instead if went straight down and crashed and bent the propeller completely out of shape.
I suspect it was either a walkie talkie issue or a loose propeller.
Thanks.
Not due to walkie-talkie.
Just a coincidence.
Most consumer walkie-talkies operate anywhere from around 20Hz to 480Hz. All of your gear is running at either 2,400Hz (2.4GHz +/-) or 5,800Hz (5.8GHz +/-). I use three 2-way radios at around 460Hz quite often when flying... no problem.
I may have calibrated it facing the wrong way since I had not flew it in a while. It may have also been a lose propeller since I had it apart.
I am glad the walkie talkie were not responsible for the crash.
20-480 hz is within audio range.
You probably meant ~450 MHz
You are correct - I was thinking CB radios, which run in MHz:
CB radio is band is HF, 26.9650 MHz to 27.4050 MHz
DonT
