Vision Sensors Calibration?
You should not have to calibrate them.
According to the DJI tutorial,
it makes it seem like you need to. I went ahead and did the calibration successfully. Should I be ok or restore to factory default?
All should be fine if you calibrated the sensors properly.
You should not need to calibrate the vision sensors right out of the box. If you'd like to do it anyhow, doing so will not hurt anything if you perform the calibration properly.
arthurbiss
