justin00 said:
Happy to re-purchase once its confirmed us android users have all the features........ a help/howto in the app would be great... Ho would we know about the taping to take photos ??
We are sorry to hear that. More info can be found at our facebook page
http://www.facebook.com/pages/Vision-Pi ... 4839160224
Vision Pilot Android
Vision Pilot Android is available at
http://play.google.com/store/apps/detai ... isionpilot
To start Vision Pilot, tag on the camera icon
Vision Pilot Features: (some features will be avaliable soon)
1. Camera Tilt Control Swipe up to pitch camera upwards and down to pitch downwards. Demo video at
http://www.youtube.com/watch?v=eGcWd92sOY8
2. Map and FPV Display
(1) Full FPV – FPV view in full screen.
(2) Full Map – Display Full map screen.
(3) FPV and Map - Display FPV in full screen and map at lower right corner
Long tap the map view to switch back to FPV and Map mode.
3. Flight Parameters
Distance: Horizontal distance from home point.Altitude: Vertical distance from home point.Speed: Vertical / Horizontal flying speed.
4. Wi-Fi Signal Intensity
Indicates camera is connected to your mobile deviceand Wi-Fi is working normally.The connection between the camera and mobile device may fail if Wi-Fi signal strength is low.
5. Aircraft Battery Level
(1) When available power is more than 30%, the battery icon is in white. This battery level is appropriate for flight.
(2) When below 30%, the battery icon will turn red. This battery level is low for flight. It is recommended that you fly your PHANTOM 2 VISION home and land it as soon as possible.
6. Aircraft GPS Status
Displays GPS status and the number of available satellites.
7. Wifi Booster
One click enhances the WiFi Video Reception Performance. It will boost the output signal up to 100% from both the Range Extender and Transmitter to increase the FPV range. Demo video at
https://www.youtube.com/watch?v=p9B9tMVJ_Ok
8. Find My Vision
Playback the previous flight path.
9. Flight Log System Record flight details of each flight (eg. GPS latitude longitude altitude speed, battery level, IMU data). Demo video at
https://www.youtube.com/watch?v=QtluZwNwEbs
All flight history records are summarized as
Different functions (Play / Pause / Fast forward) to run through the flight path and you can review the flight info (eg. battery, satellite count, location, speed, distance, altitude..) during playback.
Tag the export button to export flight history to your device local VisionPilot directory. Sample Dashware profile can be found at
download/file.php?id=15623
10. Flight Time Indicator
Remaining flight time and battery level indicator that display the estimated flight time based on the battery current discharge rate.
Real flight time is started after the the motor is on.
11. Flight Route Editor
Enter map edit mode and draw the flight route in advance before taking off and starting your mission.
12. Preflight Aircraft Status
13. Take photos
Two Finger Double Tap the video view to take photos. Taking photo is disabled during video recording.
14. Record video
One Finger Double Tap the video view to start and stop video recording.
Other Features:
Auto Recording starts the video record while taking off to avoid forgetting to turn on/off your
Toggle on/off grid line to help you set up Gold ratio of your image before capturing
Capturing image whenever your drone has moved a predefined horizontal and vertical distance.
