Ive noticed lately, most times my SD card (stock) or any of them I use, the camera wont read them.. Anybody else have this problem? What is the fix if any?
The camera is easy to take apart, there are 4 boards inside that clip together, one might be loose. A few tiny screws though so be careful if you do take it apart
Right now I got it to work. I cleaned off the contact surface of the cards. Anyhow. I have a second camera from my first drone I lost that Im no longer using. Except I dont know if it shows or records since I lost the original barcode. The cooling fan still works and I had it apart and does not look damaged from weather inside. I was guessing if I could use the board from that one in the one that does work. Ive only had them apart as much as to get a external antenna connected. I never seperated all the boards.
