Video storage
What is the relationship between the videos displayed by the "right-facing" triangle ( lower right side of "plus" monitor) , the videos in the album, and those videos on the SD card. I shot thre (3) videos - the best was displayed in the album & by > on the monitor BUT when the SD card was inserted in my computer; the best video was not displayed. I thought ALL videos were sent to the SD card. Appreciate any help.
All videos are sent to the SD card (as long as you remember to shut down recording before powering down the Phantom).
Video files on the controller are only low-res, poor quality versions.
Thank you for your prompt reply. I am grateful that you took the time to help.Why is it that my video in the "album" is NOT on my SD card when I insert it into my Apple laptop? Appreciate your feedback.
If you forget to stop recording, the files fon't get closed off properly - perhaps that's what happened?
You could do a little testing to check everything's working properly.
No need to fly to test the camera.
Thank you, Meta4 for your reply. I'll pay attention to my recording more so now. I read, earlier, that another pilot experienced the same problem. This happened to me after the latest firmware update. I would like to be able to import the "lost" video so as to edit it in iMovie. Oh, well.
Add this. The P4P, in POI mode stopped displaying the STOP button. Could not end POI, craft did not respond to normal commands and it would not land, hovering 15 feet above ground. Had to climb a hill to reach craft and grab it. Must be an IMU issue? A confused novice.
Any issue like this, you should be able to easily fix by flicking the flight mode switch out of P-GPS mode and back again
This will cancel RTH, POI, Litchi waypoint missions etc.
Grateful for your information. Provides me with an escape mode when the ac behaves weirdly. Thanks for your time and assistance.
Suprspooky
