Video Quality Issues with Phantom 3 Standard
So I am having issues with the video from my phantom 3 standard being "shimmery". I shot the video at 30 fps and tried converting it 24 fps but that did not seem to help. I shot the video on automatic camera settings. I am including a link to the video. Has anyone else had similar issues before?
That's a gimbal issue (wobble).
-Check the 4 white damping rubbers.
-Check if the 3 axis of the gimbal rotate freely, without any friction (use a camera lens air blower to clean).
-Calibrate the gimbal.
Reactions: imoffit
Agree with checking the vibration isolators, but only TWO should be in place in opposite corners. Having all 4 in place will create the vibration, or wobble, you speak of. Also, check your props for damage that would create an imbalance. There are a few tricks on balancing and truing props out there.
Reactions: imoffit
That's incorrect.
Only 2 on opposite corners have security pins installed.
All 4 corners have a rubber damper installed.
"Having all 4 in place will create the vibration, or wobble, you speak of"
Also incorrect, ALL phantoms (3 & 4 series) came with 4 dampers installed.
Reactions: imoffit
That's incorrect.
Yep. I stand corrected. I guess I should have mentioned the drop pins as being in opposite corners. You win a cookie.
Reactions: Capt KO
So I figured out the problem. In addition to installing the rubber shocks on the gimbal mount incorrectly I used four safety pins rather than just two on opposite corners. Now the video quality looks great! Thank you all so much for your help.
