video file will not play
Forgive me if this has been discussed, I did search for it.
Today I did two short flights with my new PV2. Between flights I stopped recording video, then started again. The first clip is fine, the second will not play. I am using a 32Gb micro SD card, formatted in the Vision. i just reformatted today, so it was empty. This happened before, i can never be sure if my video file will play until I get home. I hope there is an easy solution for this.
You probably forgot to hit "Stop" recording on the last video. Put the micro-SD card back in the Phantom & turn it on. Let it stay on for about a minute. The camera will look at the videos and if it sees any that aren't correctly written, it will fix them.
It didn't work, but I get the idea. I'll be more careful to stop the recordings properly.
