So I'm guessing we will use this app over the dji go app and it will show all telemetry as well? If so it may be worth it for sure.Limited (weather issues and work) beta testing but it worked as promised after first glitch. At first My Ellipse 7 only gave a dark screen, posted at vertical and it was fixed within 48 hours. Not perfect, if object blends with background it can get lost, but then I have that problem with naked eyes so I cant fault it. $20 add-on for your $1,000 toy, yep, its worth it IMHO
The walls feature is coming to iOS in the very next updateI purchased it just now. $20 is a good price...
When will the wall feature for iOS be available?
Things are working fine on the Nexus 7 now !Will this work with a Nexus 7 running Android 5.1? Only just got my Nexus but sure I read something saying it wasn't working, but that was a while back...
Sent from my Nexus 7 using Tapatalk
Yep. All you need in the air is Vertical Studio. You may use DJI GO for some on-the-ground configuration like IMU callibration.So I'm guessing we will use this app over the dji go app and it will show all telemetry as well? If so it may be worth it for sure.
That's a very good point and something we're considering adding. Course lock could help manual flight a lot. We're actually trying to move towards more automated flight paths. But what is your preference ? - automated flight paths or .... manual flight with IOC ?It seems to track very well (only at running speeds)
An issue I had was controlling it, i haven't found course lock, so if you are beside a subject and either the a/c or subject changes speed, the a/c will start to wrap around or go away from the subject, where course lock would allow you to continue in the same direction...
I've only played with it for 10 minutes...
Is the price per device or one time? If so, when I buy Android do I get IOS as well?
That's exactly how the walls feature will work. We're releasing walls on iOS in the next release, hopefully in the next 3 - 4 daysWhen will the Walls feature be available for iOS?
Can you draw walls along 2 sides of a street so that the aircraft stays in the street while it follows someone?
Any user feedback regarding Walls on Android thus far?
Apologies for this. Which link are you referring to ? If you visit our downloads page (Downloads – Vertical) you should be directed to the right download!I signed up for this and was contacted asking which version I was interested in. I said iOS and was sent a link to Android. I emailed back several times and received no response to the correction. Not very good follow-up!
