I. Before i bought the new gimbal i verified that the advanced was locked on 2mbps,
Yes, i checked the bitrate with Mediainfo on several liveview video's. They were all encoded at 2mbps and as soon i installed the pro gimbal it jumped to 6. The slider was never accessible for me on either gimbal, since i'm located in Europe.How did you verify it? Like I did, just the bitrate from the video's in the cache folder? Because mine doesnt seem locked at 2Mb. Im not getting anywhere near 6 or 10 either, but I do have 3Mb files too.
I will check tomorrow, but i remember to have read somewhere that the slider doesn't do anything when the Phantom is in CE mode, also remember i didn't get the slider at all because the auto/custom selection was not accessibe or visible in the app. Anyway will check again tomorrow.Im in Europe too. To get the slider, you just have to disable "auto", and put it on 'custom'. With me, the slider has always been on "auto", and the bitrate does seem to vary. In fairness, not to 6, so Id like to see some 6+Mb cache video's
I've never tried any distance flights, really, but have been told it can help on the really long distances.Pro guys, is it worth setting my slider all the way down before a distance flight? Is the increased range substantial?
it is limited to 2 mbs on advancedMine displays that adjustment. It goes from 2MB to 10MB. I am using the latest updated version of the app. Updated yesterday again. It does make a difference. In range and the down link quality. I have the P3 Advanced.
+1I've never tried any distance flights, really, but have been told it can help on the really long distances.
So you bought a new camera, instead of adjusting this setting at the bottom:
Which is available on both P3A and P3P.
Congrats I guess?
BTW, "auto" works just fine for me, so normally I dont even mess with the setting. OF course if you accidentally set it to custom and then 2Mb, it would be worth changing that. P3A vs P3P camera is not going to make any difference in this regard though. The lightbridge unit isnt even in the camera, its inside the VPS unit below the battery.
Nope. You are wrong. It slides from 2-10. You learned something new today.it is limited to 2 mbs on advanced
only the pro will slide to 10 mbs no matter if slider appears to work or not
So in that case you have accomplished nothing by changing the camera from an Advanced to a PRO. Since the lightbridge hardware is in the VPS unit. So what you think you see is a a huge really is not.HWCM, even though some firmware still give a slider on the Advanced, the lightbridge will never go faster than 2mb/sec due to a hardware limitation. This has been discussed several times here. The difference is extraordinary - believe me, I didn't post here to congratulate myself for wasting time and money for absolutely no change![]()
Maybe the people who say it does not make a difference have a Pro and and just assuming.On mine it works and makes a differnce in both range and image quality on my screen.
No need to. Mine works as I need it to.Maybe it is you that is assuming.......
please research this more...
