Updated aircraft firmware to v1.8.80 but it is showing as v1.5.30+ in the app
Hi,
I'm trying to fix a problem where I don't have video in the app (no video transmission signal).
I have a big list of potential causes that I need to check.
One of them is the aircraft version showing as 1.5.30+ inside the app (see attached screenshot). I did update to v1.8.80 and I'm not getting an 'update required' notice in the app, so the app seems to think that everything is up to date.
Is it normal for the firmware to show as 1.5.30+ in the app for 1.8.80 (what does it show for you), or is this indicating the issue I'm having with no video signal?
Thanks
What's inside the .TXT log file on your memory card?
I use nvidia shield k1 it's running marshmallow and I have to change usb settings everyone use for dji go app what a drag
I had an issue like that on my standard..i updated then put a different battery in and showed a different firmware with the plus at the end...where you using the battery you did the update with? Im just throwing this out there
It seems like my aircraft version simply won't update to the latest 1.8.80
[00014399]========== remo-con disconnect. boot(15) ============
[00014444]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xfbe44c6b].
[00014492]Packet upgrade start...
[00014539]Packet checking...
[00014583]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014664]Done.
[00014707]Version checking[1]...
[00014797][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014897][03 06][00] v2.4.14.5 -> v2.4.14.5
[00014955][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015098][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015305][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015432][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015538][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015646][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028204][15 00][00] device not detected.
[00028307][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028444][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028512][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028559][01 00][00] v1.30.5036 -> v1.30.5036
[00028603][01 01][00] v1.30.5036 -> v1.30.5036
[00041147][08 00][00] device not detected.
[00041212][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041256]Packet upgrade failed at version checking.
Anyone has any idea how to fix this? The weird thing is that the app doesn't tell me to update the aircraft, all status messages are OK in there.
Nwbailey
