Update and compass calibration
I thought I'd waited long enough, so finally upgraded to 3.12 - now cannot calibrate the compass however much I dance !
Any ideas, or anyone had similar ?
Mark
Did you try hooking your Phantom back up to the Phantom Assistant application to see if any errors pop up?
Also, you should always calibrate the IMU after upgrading the firmware. If you did not do that, then do that and try calibrating the compass again.
Sounds good, I'll give it s go....
WyoSurveyor
