Unable to adjust altitude in ground station app
Kansas
I've tried three different devices running the P2V+ GS app but am unable to adjust the altitude settings for waypoints. Have downloaded the latest firmware updates and that is when the problem surfaced. Did search via Google Custom Search but don't see this discussed. Any ideas?
Just to be sure you are doing it correctly. First you set a waypoint, then tap the waypoint and you should see a slider where you can adjust the altitude for that waypoint. It is touchy and not very precise. If you use Coffee's custom version of the app, you can set a default height for new waypoints (not sure if that is in the stock app?). You can then adjust the altitude for individual waypoints by tapping on them.
I can adjust the slider and then hit enter but it won't change the altitude. Need to play with it some more, I guess.
Where can I find Coffee's custom version?
Thanks, Dirtybird.
Nip
