GROUND STATION NOT SHOWNG MAP - Request Help
Hi,
I am in a fix. Please help.
I was using Ground Station 4.0.11 downloaded in 2016 on my MacBook Pro with Bootcamp running Windows 7.
Recently, it has suddenly stopped working and the message I get is "Maybe the network is not good. You can try to open the GS VPN(Sys_set->Options->Network Settings->GSVPN) to load the map.
However, the internet connection is good and Google Earth is working otherwise on my Macbook.
Please help urgently if possible.
Thanks,
Nitin
I have same problem, I try to re-install but it doesn't work. Also try to another computer, the result is same (not worked).
Is there any suggestion ?
