TickTock said:Although the author gets high marks for his apparatus, the experiment is rather poorly defined. He compares a 9" tri-blade to an 8" bi-blade. This really yields no useful conclusion. He should compare same diameter blades to determine what the thrust is for a given amperage draw (tri should be less thrust for the same current) as well as what is the max thrust achievable (tri should provide more thrust).fizzviic said:I ran across this yesterday on another site. Very interesting. Seems to contradict most thinking on the subject.
http://youtu.be/hYr3a8b85r4
Thats comparing the props assuming you arent limited in prop size, I dont think there is any doubt that a 3 bladed prop is less efficiant then a 2 bladed prop when comparing a similar lift prop. 8x4.5 tri and 9x4.5 dual will give very similar lift and if you have the option of either then it would be silly to not go the larger dual bladed prop.
But then when looking at a heavy phantom 9x4.5 is still not quite as much lift as you want and 8x4.5 is really limited in lift. 9 inch blades are the max size we can use due to the frame size and design of the phantom. So we then get the choice of 9x5x3 or 9x5x2, I used 8x4x3 on the phantom and these are pretty useless as they were too small and flimsy with no noticeable advantage in lift over 8x4x2 or obviously 9x5x2 props so 8 inch triblades are going to lose over 9 inch dual blades of the same design and pitch.
The 9x5x3 props will be very similar in total lift as 10x4x2 props which is pretty common on a f450 using the same motors as a phantom. These would likely be a better prop then 9050x3 GWS and there are also more options in stiffer 10 inch props whilst we are very limited in the options when it comes to 9 inch triblades.
So using that video as an example it just shows what I think most people already know about dual blades and triblades in terms of efficiancy. But the problem is if your craft is too heavy to be easily lifted by the largest dual blades you can get and so going triblades will have an advantage and I think this is pretty clear in my use and many others that have also tried these particular props on a phantom.
bumper said:In aircraft, just considering number of blades (all else the same), the fewer the blades the more efficient. So if that's the case (and it is!), why even have 3 or more blades? The answer is really simple in aircraft, during WWII as engine power increase in the effort to maintain air superiority, they quickly reached a practical prop length limit for ground clearance. Prop efficiency took a back seat to the need to harness more horsepower, thus 3 and more blades, wider paddles, and even counter-rotating props where used towards the end of the war.
Now in GA aircraft 300 hp and up is about the point where a 3 blade makes sense.
bumper
I think thats exactly the point when you are limited in blade length then more blades will give you more thrust or lift. If size is no issue have a huge dual bladed prop like a regular heli but when length is limited and you need more lift then getting more blades is the only real option.
Now that v 4.0 firmware has altitude limits preset I will be able to fairly easily do a real world lift comparison of the props I have. I will simply set my altitude limit to maybe 100m and then on a calm day launch from ground to 100m and see how long each takes to get there at full throttle. This should show real world lift differences between props and I will also show throttle position needed to maintain a hover with each in manual mode. Having flown all my props I have a pretty clear idea of where they all are and as I fly lots in manual mode I can easily tell the lift differences between each by the amount of throttle needed to maintain level flight or a hover.
Some props like graupner 8x5's are the worst lift by a long way in my tests and I get less then half the flight time using those compared to stock DJI plastic 8045 props, this is easily seen in less lift and therefore though they may be the most efficiant props I have they get the worst performance and flight time due to very low lift of these. When I first tried those thats when I started realizing that a prop with more lift may end up giving more flight time and performance then what I was currently using. I then moved to 9x5 graupner clone carbons and 9045 carbon DJI clones. The 9045's are clearly better at providing lift but I really wanted to try a larger prop but 10 inches is impossible on the phantom and so I figured it cant hurt to try some triblades. I was unsure about the effect of reduced efficiency vs more lift would work but was quite surprised that the added lift still ended up giving longer flight times vs the more efficient but lower lift dual blades.
The 9x5 graupners are close to stock 8045 props and so I see very little reason in those too other then looking pretty cool. The 8 and 9 inch DJI clone carbon or nylon carbon props easily outdo the graupner profile props on a phantom and you do have a good choice in prop stiffness when using these. I havent flown the 9x7x3 props yet but being quite a bit heavier and higher pitch I dont think they will be that great on the phantom but will see once I test them.
I still prefer to fly 9050x3 GWS props but would love some stiffer versions of these which if well built I think would be a near perfect fit for a phantom. Even DJI has moved to 9 inch props for the vision and phantom v2 as they have realised the 8 inch props are not producing enough lift and using larger props will give better flight performance and battery life once you start upping the weight quite a bit.
