Traveling with your P4P by plane...
The bundle deal that I got on Amazon came with this backpack .
mine will hold 2 batteries inside the foam case along with the one that I leave in the AC. Same backpack as posted above , great price , great product , lots of Room. IPad 2017 and Sun shield and outside front compartment, Extra propellers in outside side compartment, inside is Wireless passport hard drive ,camera lenses , AC w/bat ,RC, 2 bat ,small wires. Upper outside compartment has parabolic antenna , battery charger, Over the shoulder lanyard harness,SD cards and Adapters.
://www.amazon.com/gp/product/B01J7UN1G8?tag=phantompilots-20
That's an inexpensive way to carry your drone using the OEM Styrofoam box, but it doesn't comply with FAA size requirements for carry-on luggage to travel by plane.
Post number 15 didn't seem to have any trouble!
Many times people take non-complaint sized carry-on luggage, and they get away with it, we've all seen that. However if the attendants start getting picky you could be denied. This occurs mostly when flights are booked full. Potentially being denied is a risk I wouldn't recommend taking. If they mandate you to check your drone, now what are you going to do? Are you going to remove the batteries and carry them on and hope your drone isn't mishandled in cargo? Will you be prepared to carry the batteries by themselves? Getting a good backpack that's size compliant with FAA is worth the money IMO. I want no surprises.
Traveling with a drone...
Just could not disagree more with John Locke. I travel frequently with my P4P in a hard case. I always check it; carry all 5 batteries with me on the plane (if there are restrictions on the number of batteries I have not seen that in print on the airlines I fly on) and you NEVER tell anyone connected to the airline that you have batteries in your carry-on...never! It is not a safety issue and there are no FAA restrictions on the number...only the wattage. My hard case, from OGPC, is terrific! More space than in the backpack and far more protection and customization capability. Putting ones drone in the overhead on a full airplane when you are in Boarding Group 4 is iffy at best. Other pax jam bags in the overhead and, if the cabin crew decides that the overhead is full you are required to check your
backpack. A soft case in the baggage hold with a hundred hard suitcases? Not just NO....but, really, really NO. My hard case has wheels, handles , an extensionable pull handle and is tough enough for anything.
I use TSA approved locks on the case just to keep the honest people honest. I also leave an inventory list inside the case where TSA thieves
will see it. My case has never been opened. I put a special tape on the case so if the bag is jiggled/pryed, the tape distorts and attempted theft or opening is obvious to all.
Another benefit to a hard case is customizing the interior foam with an X-acto blade for other than standard parts. I can carry considerably more in my hard case, more securely, in my hard case than I can in the backpack it came with.
Sometimes TSA looks into my carry-on at the batteries...sometimes they don’t. I travel to DCA, SAN, IAD, IAH, DEN, DFW, DAL, BOS, MCO, ORD, IND, BWI and others. Never a problem! Most TSA folks are very interested in drones!
As far as protecting against shorts...much ado about nothing. A piece of
black electrical tape across the contacts will do it. Wrap them all in micro-fiber cloths for some minor cushioning and press on.
As far as the case being lost...in the old days lost bags amounted to about 5-7% of all checked bags. Now, computerized tracking and much better handling procedures make permanently losing a bag unlikely. If you check your own bags you get the bag tag yourself and can check it for accuracy to your destination.
Hard cases, check them, carry your batteries in your carry-on and relax!
Jetjockey6
Yep, we disagree. I prefer keeping my drone with me on the plane so only I handle it, no risk of losing it. Throwing the backpack over my shoulder is way more convenient on travel than lugging a hard case weighing over 10lbs more, everywhere I go, including hiking and biking. Try that with a hard case.
Reactions: roosta
hcashmore11
