This advanced IMU cal sticking is annoying.
Sure its not one yellow and three reds? Indicating switch in ATTI mode with 5 or less satellites.
Are you in phantom mode or naza mode in software when connected to P2 using Phantom Assistant software?
Mako79 said:
****PLEASE DO NO]T IGNORE THE MC HEAT WARNING****
****PHANTOM WILL NOT CALIBRATE*****
Yes you CAN IGNORE the warning. Still got it after my Phantom been in the fridge for 3 hours. Its a bug.
Sent from Samsung S4 via Tapatalk
Folks these are all great suggestions. Maybe I was not clear in my first post, this is the phantom that went swimming so we can't rule out possible component failure. Right now, I suspect the GPS is what is bad. I will have to take a computer outside (or get a really really long usb cable) to check the validity of this thought.
Also, I took the gimbal off as it is clearly malfunctioning. In the software it shows that a gimbal "switch" is on, but I find no where to change that in software or hardware.
Probably time to order some parts....
THANKS!
sj
Agree, but, if it's been running for a while even just on the bench in standby it can get too warm and then it may not complete.
You get a vicious circle of waiting for it to complete/getting warm/wait longer to complete.
If it doesn't do it in 5 minutes or so, switch off and try again after an hour or so.
cahutch said:
cubdriver said:
..., all I ever get is slow flashing yellow in any mode - GPS or ATTi and when I try to start, it gives me five red flashes and goes back to slow yellow..
I think you're stuck in atti mode.
Possibly a broken S1 switch. They are prone to breaking due to the compass calibration method.
Maybe a bad GPS module, happened to me. viewtopic.php?f=27&t=22444&p=221469#p221469
I do not notice that. I am going to put the software on a notebook this afternoon and take it outside to test. I suspect it is the GPS.
sj
If its a bad gps you won't see it in the assistant. It happened to me on my 450. Wouldn't show up on the Rc page.
MS60
