Have a phantom 3 professional and I had a little crash replace the camera look at the motherboard notice there a little capacitor fell off can I solder it back on or do I need to buy a whole new motherboard?
I can definitely solder it. I just didn't know if I need to just solder the two leads back to the broken off Leeds on the motherboard? And you so you think everything will just work properly
Not a very clear picture but look for the correct orientation as that is an electrolytic capacitor and polarity sensitive. would also use some hot glue to support it.
And also if I was to solder it back on what do I have to do take the board out and get the little pins to go through the other side of the board and touch the circuit is that how that works
It's 220uf 35v.... easy to find in SMD. Any 220uf electrolytic with 35v or greater value will be suitable. Just make sure you use some silicon When you mount it.
It's an SMD, not through hole. Just tin the pads and sweat it on with as little heat as you can get away with. From how this is sounding it may pay to get someone to do it. The board doesn't need to be removed.
