Tarot T2D Gimbal Tilt Issue, Not Going Up
Hi,
I've been having an issue with my tarot t2d gimbal and was hoping if somebody has a solution for me.
The gimbal has been calibrated and configured but without any results.
When I move the lever on the back of the controller the gimbal somehow doesn't respond when it should go up.
It does respond when it needs to go down, but when it reaches it's minimum I'm not able to bring it back up again.
I've checked the NAZAM Assistent and the X1 channel seems to work fine and responds to any direction I shift the lever.
Though still the gimbal won't respond.
For some reason it works just fine when I plug it in for calibrating, but in some cases it still didn't work..
I made a short video to explain what I mean:
https://www.youtube.com/watch?v=vx1etiI ... e=youtu.be
I hope somebody can help me out with this, right now I'm pretty stuck..
Thanks!
I recently noticed that in some cases it suddenly starts to work properly again.
The phantom was high up in the air and suddenly the gimbal twitched a bit and started responding to the position of the lever.
This was after a couple of minutes so I couldn't really make any shots because the battery was almost empty.
robvalduga
