Tablet/phone holder P3S
Southern Indiana
Got the idea from YouTuber Conner McGraw! Works great.
Sent from my SM-N920V using PhantomPilots mobile app
Clearly you don't need help or advice. You wanted to show off your mod. Gold star!
And not a **** thing wrong with doing so. Congrats!
+1 on that. Sometimes others might be interested in doing the same. Have a table mod on my P3S as well, but went the way of an "Inspire 1" tablet holder.
Reactions: Drocken
My remote with inspire tablet holder:
My Inspire mobile mount just arrived today and the arm is made of aluminum. I've seen some of my friends' P3A or P3P remotes and their mobile mounts are made of plastic, similar to your picture.
Which got me thinking... Did DJI released a plastic and aluminum version of the mount for the Inspire?
I went back and forth whether or not to do this mod. I settled on the other because it didn't require any drilling. I haven't had it long enough to start drilling! I am sure I will get braver. I want to do an antenna mod eventually so I may have to do it then.
Finally got around modding my P3 Standard remote.
The Inspire 1 Part 45 Device Holder arrived in the mail a few days ago.
Pilot hole. You've got to have lots of patience or you end up scraping/scratching the case or worse, accidentally cut any of wired inside.
Checking the alignment
Once the correct hole size has been drilled, in goes the threaded nut.
Tightened the threaded nut from behind and put on a bit of hot glue so the wires won't go anywhere.
Any voila! The finished product.
ctlfreak
