Tablet Holder
Will the device holder on the Phantom 4 controller handle an iPad Air 2? If not what size tablets will it handle.
Yes. It can hold a tablet that is up to 6.75 inches wide (including the case if you're using one).
msinger...that would seem to eliminate the iPad Air 2 as it is larger than that. Thanks for the info.
The iPad Air 2 just makes the cut.
I guess my case may be larger than normal.....but it does look like the tablet makes the cut. Thank you again. You are a wealth of info.
Yes it does hold the Air 2, I use it for my P4 but no case. Why case on the pad? You want it cool not hot.
