T Motors Anti Gravity Props
Missouri
Hello
I have a new set of the 9x TMotors props for the Phantom 1.1.1 with DJI stock motors.
I have not installed them yet - but for a test- i put one one the motor shaft and it clears the body of the phantom by a 1/4" or less - hmm pretty close but it clears - they do hit the dji prop guards and they extend past the edge of the guard, so those need to be swapped out for carbon fiber ones that are much lower by design.
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=165_177_179&products_id=2220
Is any one here using the 9x TMotor props on there phantom??
If so, is that ok that there so close to the body arm of the phantom?
and did you have to make any software adjusts for them??
Maybe i should send them back and order a set of the DSLRpros or Grapner 8x carbon prop set?
Im not giving up until it flies someday....
Looks like nobody has - so I'm sending them back on monday
and keeping the DSLTpros CF and Grapner props 8x's instead
intertronixlabel
