Strange stick reaction / DJI Pro 4 questions
When I forward and up, my drone rotates. I've done the controller calibration. Any other ideas?
click on remote calibration,,it tells you to turn ac off and follow other prompts it tells you
Same problem with ALL settings in DJI Go 4!
If I X out, the setting stays; but if I go back, the setting resets.
So, apparently you can't make settings adjustments while the drone is off. That's just silly.
I'm thinking differently, the package must be powered up for the settings to stick so that the changes are retained. You need the same set up to review your current settings so it makes perfect sense. I used to run two different quads on the one device and my expectations of each were completely different.
jeetbuzz360
