D
Deleted member 29014
Guest
Your recommendation: can I get better resolution stills if I clip them from 4K video than using the best resolution the P3P camera provides for stills??
Thank you very much.Photos taken in RAW format will give you better quality after editing the photos in a program like Adobe Lightroom. If you're planning on using the photos as-is, then pulling stills from 4k video would be a good option.
thanks. good to know.Stills from the P3P are taken at 15Mp. Stills pulled from a 4k video are about 2MP. No matter what mode they are taken.. a still will produce a far better image.
Eh? Stills have 12MP i think and 4K is like 8MP. With Full HD you get 2MP stillsStills from the P3P are taken at 15Mp. Stills pulled from a 4k video are about 2MP. No matter what mode they are taken.. a still will produce a far better image.
If you do the math, perhaps its a little higher. But that doesn't directly relate to picture quality because of compression. At the end of the day though, it changes nothing. The still image is far superior.Eh? Stills have 12MP i think and 4K is like 8MP. With Full HD you get 2MP stills
yes but the amount of MP for a 4K video is 8,4MP i think when you do the math. So its not that far away from 12MP but the still should be better, most of the time 4K stills are enough. Stills have of course teh advantage of choosing the situationIf you do the math, perhaps its a little higher. But that doesn't directly relate to picture quality because of compression. At the end of the day though, it changes nothing. The still image is far superior.
When taking a 16x9 photo is it just a cropped 4:3 photo resulting in a Low quality image (is this even possible)?Yip Steve you have it right. Its just the compression that makes the stills from 4k video look worse. The 16x9 ratio video is shot in means it wont be a full 12MP as a 4x3 ratio still is but it wont be much smaller than 12MP
Yes, a 16x9 photo on this camera is a crop of the 4:3 image.When taking a 16x9 photo is it just a cropped 4:3 photo resulting in a Low quality image (is this even possible)?
Thanks
