Stability issues - Right turn only
Having issues with stability to the left side (Right turns). In video, you can see how it "hiccups" to the left, but it never does it to the right. Even when I turn quickly. What should I do? Less than a month all. 20 flights total. 340 minutes of flight time on it.
[youtube]https://www.youtube.com/watch?v=q8Trb8gcUeQ[/youtube]
There were reports of the 3rd axis motor rubbing on the Phantom and "sticking" just enough to cause an issue.
Pull your battery out and look at the battery where the 3rd axis gimbal motor would be and look for rub marks. If you have a clearance issue you need to put some washers under the mount...
If that is not it look VERY carefully if it's not touching something somewhere.
Good luck
Don carlos
