I got one. The mobile holder part was loose so the tablet's (iPad Pro 9.7") angle wasn't steady (with the two plastic washers). So I fastened that screw just a little bit with a screwdriver, then again, then again ... until finally the thread of the screw gave up and got completely loose.
I ended up ordering the original plastic DJI bracket. Yes, it wobbles a little but it does its job.
I read similar experiences about a loose FAA Drone Decals Stability Bracket tablet angle here. (I didn't complain to the seller because of the inconvenience/shipping costs etc doing that from abroad).
The marketing gal promoting the bracket here admitted that the plastic washers don't work and suggested getting similar metal washers (this thread was later deleted from the forum so don't bother clicking it):
"After a short time of use with the OEM bracket as you adjust the screens position it starts to flop forward and backwards (won't stay in place) because the plastic bracket starts to ware thin.
The replacement Stability Bracket has two plastic washers that take up that slop left over from the the ware on the OEM plastic bracket; if that isn't tight enough for your liking or if your tablet holder is two warn down from use, then just replace the two plastic washers that come with the new bracket with lock washers of the same size, that will completely eliminate any screen tilt on any size screen.
Just use washers like these from any hardware store in in-place of the plastic washers."
http://www.phantompilots.com/thread...ity-bracket-very-impressed.76742/#post-786105
