Space Needle drone strike.
operative word is "almost". If any incident was going to cause an injury of fatality, it would probably be some dip wad like this violating a whole bunch of rules and common sense concepts. just like the old saying, "it only takes one OH S&*%T to wipe out a thousand 'at ataboys'".
With as many drones that are flying around out there, isn't it interesting that (as far as I know)--there's been no deaths from drones falling out of the sky (we're talking drones falling, not hellfire missiles)? I mean, coconut trees dropping their coconuts are blamed for 150 deaths per year; but no one complains about them growing around beaches with large crowds of people... :p
I am wondering how much additional radio frequency interference he may have run into. Isn't that an antenna on the top of the Needle? He could have flown into an area where RF oversaturated the drone's electronics and cause an auto return.
I've never had that problem when flying around the Space Needle.
The early reports are that the operator was on the ground at the base of the structure. Someone correct me if that's wrong, but if so:
When you're flying hundreds of feet directly overhead, you're not in an optimal antenna position. It's possible that if the op had the antenna in the normal "flat facing forward" position, the AC would have been in an antenna dead zone.
Instead, in such a case, the antenna should be parallel to the ground, flat facing up. Even then, it's still not a great signal.
On top of all of that, if the craft went behind the structure, there would have been no signal at all, so RTH.
Chris
There's all kinds of stuff at the top of the needle... radio antennas, cameras... etc. in this case fireworks and computers..
Obviously the cops or the needle or someone pulled the SD card from the Drone because I think the video posted came from the Drone?
There is a news story of a kid that was filming it with a iPhone as it hovered outside the O-Deck. He even got a prop piece that landed right next to him.
I guess the odds of this happening are slim, but I can't stop wondering what would have happened if it rolled off and onto people
Technically, the FAA rule is 400' near or over a structure. So if the Needle is 605 feet tall, he could be legal up to 1,005 feet as long as he stays within 400 feet of it. There is a question similar to that about a radio tower inspection on the Part 107 test.
However, the problem may soon be solved as one WA rep is wanting to make flying a drone over anyone's property trespassing without their consent: (WA HB1049) WA - HB1049. This could make WA state the new Sweden and ban them outright unless over your own property. Same guy trying to keep drones 600 feet from whales too.
I believe the the new WA law being proposed only makes it illegal to be over someone's property below 2 or 300 feet. As long as you are above that, its still ok.
Check that. I read the text of the bill in the above link and saw no mention of any altitude minimums, just you need permission over someone else's property.
"BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF WASHINGTON:
Sec. 1. NEW SECTION. Sec. 1. A new section is added to chapter 47.685RCW to read as follows:
(1) It is unlawful for a person to launch an unmanned aircraft in Washington state without specific federal authorization unless the unmanned aircraft is clearly and prominently labeled with the name and phone number of the unmanned aircraft's owner and operator.
(2) It is unlawful for an operator of an unmanned aircraft to, without specific federal authorization, operate the unmanned aircraft over real property lawfully owned or occupied by a person, other than a public agency, without the consent of a lawful owner or occupant of the real property.
(3) Subsections (1) and (2) of this section do not apply if the unmanned aircraft is lawfully in the flight path for landing at an airport, airfield, or runway and the unmanned aircraft is lawfully in the process of taking off or landing, pursuant to specific federal authorization."
No doubt the knee-jerk reaction to the Space Needle crash will add some fuel to the proposed law. If this passes, may as well give up flying anywhere in WA state other than your own property. Might pay to get a signed property release otherwise.
The WA law appears to me to attempt to cut the FAA out of there rightful position as the one and only agency in charge of airspace. Imagine a world in which every state imposed there own set of rules -- there would be no commercial and certainly no private aviation if compliance required meeting all 50 states rules.
It's my guess that among the folks pushing these rules are business interests that would prefer that the public not be looking over there shoulder. Having regulators is bad enough but with them its often pretty easy to apply some pressure with a state or federal elected official and have them put pressure on the regulators to back off. But, controlling the public is harder and would require greasing a great many more palms and that can get expensive. A few years ago an environmental group flew a drone around a Texas ranch and caught the rancher dumping crap into a waterway -- was the rancher fined or in anyway punished, no, in fact the local authorities imposed an ordinance to prevent drones from flying over or near those areas.
Brian
The person operating the drone was truly not aware of or not complying with the rules set by the FAA. It reads "500 feet from non-participating people and from buildings". It's just that simple. I'm sure we will hear about what the FAA is going to give that operator as a fine when they find him or her.
As you are......
There is no such "rule" in the United States that says anything close to this.
He most likely will not be fined.
Reactions: Digital.Gods
I could see the FAA pulling out the "Reckless endangerment" clause to go after the guy even if he flew within their current rules. There's always a gray law in the books somewhere to come up with something to charge someone with. Public opinion carries a lot of weight too in generating a gray law, and drones aren't high on the list with many as is.
Bad part is it will give the WA Rep. Morris (D) more fuel to push his anti-drone bills (He's got a couple.) through the WA legislature and curtail a lot of drone activity and also give the police more power to cite or make arrests without approval from the property owner's land that they fly over or encroach on. I can see them confiscating drones as evidence too or at least their cards.
Reactions: skyeboysteve
That was thought while viewing the clip.
The area beneath the Space Needle ALWAYS has lots of people milling about. If a coin dropped from that high it would probably kill someone let alone a UAV.
Sent from my SM-J700T using PhantomPilots mobile app
The old myth about a coin dropped at high altitude could kill someone, is just that 'a myth' - you can read about the physics of that here Could a Penny Dropped Off a Skyscraper Actually Kill You?
However, a drone or drone battery falling on people from that height could be disastrous.
I'm going to take a guess that this guy was not a 107 certified flyer. If he is then he had better have called
KENMORE AIR HARBOR Phone: +14254861257
SEATTLE SEAPLANES Phone: +12063299638
otherwise he will be fined for not notifying (in addition to other things).
A clear violation for a commercial pilot.
right-of-way provision of § 107.37(a),
5.8.1.1 Remote PICs are prohibited from operating their small UA in a manner that interferes with operations and traffic patterns at airports, heliports, and seaplane bases
Also I can only imagine that there are a lot of people under the space needle at most times so he will be fined for that if he does not have a waiver to fly over people. 107.39 Operation over people
Somebody above mentioned "500 feet from non-participating people and from buildings". this is from the 333 and has no bearing on this case. That being said he did hit a structure and almost some people so he will probably be fined for that. 14 CFR 91.13 - Careless or reckless operation.
If he was flying with a 107 cert. then he could technically fly high enough around the tower to be where he was altitude wise, but as a non-commercial pilot 400 ft AGL would be the limit, so he will be fined for that.
107.51(b) Operating limitations: altitude (even as a non-commercial this will apply)
The city and state can not tell him he can not fly above a park, as long as he takes off and lands outside of the park, as airspace is ONLY controlled by the FAA. The city and state can pass whatever laws they want about the ground but the parts about flying will not hold up in court.
Of course with idiots like this though it will not be long before cities start to pass laws saying that you can't take off from anywhere on their land.
If he is a 107 certified pilot and did notify heliports and seaplane bases, fly from legal ground, and get a waiver for 107.39, or clear the area below where he was flying (I doubt all of this) then his operation would be perfectly legal and this is just an unfortunate accident. IF all that were true than the FAA would most likely not fine him for 14 CFR 91.13 - Careless or reckless operation if the aircraft was in RTH and unresponsive and he followed a plan of action i.e. calling the ATC to report the situation. But that would still be the FAA's call.
Most likely the pilot was just a ******* that did nothing but launch without a thought to where he was or who he was endangering and he should pay the price.
Reactions: Clinton Balmain
I know the one time I set my altitude higher than 396 ft, I did not fly and I was in the country, my DJI app was more than happy to let me know that I would be exceeding FAA regulations.
As a 107 pilot, this is not true.
1- 107 pilots DO NOT contact any airports for anything.
2- This area is in unrestricted airspace, therefore no airspace waiver is needed for a commercial flight.
3- There is no control tower of a paved runway airport with in 5 miles, so flight as a hobbiest in this area is fine.
Why are you adding additional details such as pavement and tower?
Where are those qualifications stipulated?
MS60
