Solid red light on the gimble. Need Help with solution
Check the three plugs going to the gimbel from the quad. Make sure they are tight. Make sure your SD card is good and has free space and lastly make sure the camera firmware is the latest version.
See if that clears the red light.
Have the same problem camera red light on, all updates done. Never crashed. What was the fix?
Does the gimbal firmware show up in the Phantom Assistance software?
Double check the three cable connected to the gimbel. Make sure all cables are plugged in tight and there are no loose wires or pins pulled out.
All plugs and cables checked ok. I reloaded the camera firmware and all is well now. No more red light and everything works just fine.Thanks guys
jack klausner
