Solid red light on the gimble. Need Help with solution
Discussion in 'Phantom 2 Vision + Discussion' started by Mike Stephens, Aug 13, 2015.
  1. Mike Stephens
    Can not get camera connection due to solid red light on gimble. Does anyone know what the fix is?
  2. RoyVa
    Virginia
    Check the three plugs going to the gimbel from the quad. Make sure they are tight. Make sure your SD card is good and has free space and lastly make sure the camera firmware is the latest version.
    See if that clears the red light.
  3. 3rdworld
    Have the same problem camera red light on, all updates done. Never crashed. What was the fix?
  4. Mako79
    Sydney Australia
    Does the gimbal firmware show up in the Phantom Assistance software?
  5. RoyVa
    Virginia
    Double check the three cable connected to the gimbel. Make sure all cables are plugged in tight and there are no loose wires or pins pulled out.
  6. 3rdworld
    All plugs and cables checked ok. I reloaded the camera firmware and all is well now. No more red light and everything works just fine.Thanks guys
Similar Threads - Solid red light Forum Date
Solid 4 Red lights Standard/4k Discussion Jul 3, 2017
Rear lights solid red - just for 3 or 4 seconds - flies normally Phantom 2 Discussion Jun 19, 2017
P2 Vision+ solid red light on gimbal, no live stream, no gps. Please help. Phantom 2 Vision + Help Apr 16, 2017
Professional Solid Red Light During Firmware Update Phantom 3 Help Feb 26, 2017
Solid Red Light On Gimbal and Warning sound Phantom 4 Help Jan 21, 2017
