Solar Power?
Los Angeles
Need some advice on power! Need to solar charge my drone (P4) on my Iceland trip (and other devices). Thinking of buying the Sherpa 100 by GoalZero. I have a budget of $600. Any suggestions of anything better?
It's only 8800mAh which might give you 1.75 charges.
Hi Up Sonder-
I'm designing a solar charger specifically for the P4 as we speak!
Would you need a USB port also, or just the charger for the drone battery and controller?
John
It will take 10 hours under optimal conditions to charge the Sherpa 100. You would also want the Sherpa Inverter module to provide the AC outlet for the battery charger, but if you are getting the kit then you get the solar panels and the inverter with the charger. The Wirecutter liked it. If you are completely off the grid, then it looks like you would get two flights a day with it.
Nip
