i tried a install window driver installerr..it wont install in my window 10 pc..for phantom....theres a error...my pc cant identify my drone..whats the solution
As I said, I'm not a Phantom1 owner, but a search here (the magnifying glass, top tight of the page) found me this thread.
I have a MacPro Quad Core but I can only find windows software on the dji site. Millions of us have Macs - what do they do. I have a new Phantom1 with 2200mAh battery {which I assume will only run for about 10-12 mins?} Should I buy another one if I want to play for more time?
phantompilots.com
So first of all, is your drone turned on when you try to connect?
I did another search here with keywords 'windows driver P1' and got these results.
Search results for query: windows driver P1
Read through the results and there are some that might help you. The copied extract below is interesting and talks about problems installing the Windows driver on Windows 10. In post #7 it's written :-
The assistant and driver suitable for your Phantom are in the Download section at this address.
DJI Phantom Drone (that's the same link as I gave you in post #5)
Do not use more recent versions, because they apply to Phantom 2 and later.
If you have trouble in installing driver under Windows 10, first modify the PC date and time to 2014, install the driver and assistant(better if you run as administrator) and when everything work, go back to the current date and time. "
phantompilots.com
@Anni65 Don't forget about using the search engine here! It could help you find an answer to your problem.
