Software problems
Hi all.
When I try use Nazza m assistant it says no main controller connected. I have the same issue with iosd mini assistant however it works fine with phantom 2 assistant. I've just added an iosd mini & immersion rc 600mw to use with a black pearl monitor.
The iosd mini only flashes green & every answer I get is to update it but obviously I can't is the assistant can't connect to my p2.
Any ideas? Am I missing something obvious?
Ryan
1. The NAZA-M Assistant isn't for the P2....you need to run the P2 Assistant and change that to NAZA-M mode. The one you're trying to run works for P1's and other multirotors using a non-P2 NAZA.
2. To update the iOSD mini, you will need to connect the USB cable directly to that component and then run the OSD Assistant.
Thanks OI.
So I don't need naza m assistant at all? I have changed P2 to naza mode so I guess that's all I need.
I have plugged USB direct into iosd mini but it does not get connected to iosd mini assistant. Possibly faulty unit?
