Software - follow a KMLpath
Hi all
I am looking for software that is able to let me follow a given route marked in a KMLfile.
Now I have to switch between the Earth app and the DJI GO view, and that is not very precise
It would be nice if the route was marked on the map in the GO app, instead of seeing the Google Maps map.
How can that be done?
Cheers
Jesper
Figure out the format in which Go (or Litchi) stores "missions", and write a converter. KML format is open, so that part will be easy.
Here is a video on KML file which stores path with height, drone rotation and speed etc.
Your converter would have to create such data, assuming you only have a simple 2D path.
Looks like some versions of Dji Go do support KML files:
Use GS Pro. You can import your kml file. It will show on your map as you fly you can view it in either the main screen or the PIP.
