Small, light, powerful strobe lights...
gunslinger
Moderator
Premium Pilot
Least Coast...
It weighs 200gms! eek!
Sent from Samsung S4 via Tapatalk
gunslinger said:
I'm looking for a small, light, bright strobe to mount on my P2V in case it goes AWOL. So far I've found this one from China...
http://www.ebay.com/itm/Car-Flashing-Li ... fresh=true
Anybody have anything similar?
Thanks...
-slinger
they are not small m8 we have some amber warning versions of the car in the event of breakdown and they about 4" across !!
I use strobon white navigation leds's :
http://www.flytron.com/rc-light-systems ... light.html
http://www.ebay.co.uk/itm/3Pcs-2xCR2032 ... 5aff16487f
You can wire them to the batteries but I just made a small button 3v battery module which weighs very little and you just solder the wires to the led module and just silicone it to the back of button battery case. I only use it when you fly at dusk or whenever you want to and they are quite impressive in the dark even at long distances lol
Let me know if you want a photo. Only takes 10 mins to make and attach it with the velcro pads we all use.
Thanks...
-slinger
You can wire them to the batteries but I just made a small button 3v battery module which weighs very little and you just solder the wires to the led module and just silicone it to the battery compartment. I only use it when you fly at dusk or whenever you want to and they are quite impressive in the dark even at long distances lol
YOW!!! I've gotta pay more attention to size and weight. I looked at so many flippin' small strobes today, I just zoned... :shock: :shock: :shock:
Thanks for the wake up call, guys...
-slinger
Thanks, Pyro... A picture would be excellent...
Thanks again...
-slinger
OI Photography said:
If you need a US source for those, it's the same strobe RMRC sells at that link I posted.
TY, sir... :D
-slinger
Why does it have to be a strobe. I have a couple of the cheap 3 white led flashlights....about 2 inches long and 3/4 inch in diameter. It weight 22 grams with little loop and chain. I agree a strobe is more effective but these are only a few bucks and can be found everywhere. Just a thought
See it flying and you will see why - you wont see a flashing led at 1000' but you will see these !....oh and this is actually a 1W strobing LED
Hey up to you what you want m8 I wanted something I could see at distance when getting dark, im not forcing anyone to make these lol
:lol:
Clue is in the question..."strobe"......secondly, it weights next to nothing, it is easy to make, you can have it attached or not attached. Im not saying this is what people should have, merely what I use in answering the question ??? You want white leds on your phantom fine, im not criticising your choice or saying "oh why do they have to be white LEDs".........chillout man !
I'm looking for a strobe to use as an aid if my P2V decides to fly itself to an unknown destination. If the strobe will flash for many hours using its own power source, it would be easier to find than just a bright light... IMHO... :)
-slinger
pyrophantom said:
Here it is :
Thanks again, Pyro... I think this is my solution...
-slinger
Monte, the key factor is that your peripheral vision will probably notice a flashing light sooner and at a farther distance than a solid light of the same brightness. Even when you're looking at it straight on, a strobe is easier to spot in general.
Well said m8 and these are bright strobes !!
:D
sansuciboy1
