Not to sure on this set up but you know your remote should have those brass gold plated ends inside those silver chrome antenna holes with nut on top to secure them so wire not get moved around or plug torn out of board,,,I just have quick look but me think these need power source to work,Signal quality bad after putting on 2.5 watts sunhans boosters. Does better when I attach just the antennas. Any ideas?
,,,ok found this but you already got power,,I see if I can find diagrams of set upSignal quality bad after putting on 2.5 watts sunhans boosters. Does better when I attach just the antennas. Any ideas?
Signal quality bad after putting on 2.5 watts sunhans boosters. Does better when I attach just the antennas. Any ideas?[/QUOTe,,,ok found this pic but can't find one that shows proper install of it
Is it possible when you got that bad channel 13 on auto,,what happen when you select custom and choose a channel,,does it stay the same,,auto is finding channel for you but manual you can select oneScreenshots of pictured setups signal strength.
Gezz tricky one,,tryed change the 2 top antenna ones around,,does that do anything,,looks like set up good so running out of ideas,,It just cuts out the same on manual
Daniel.......Only because you First said it.....Yes I agree.Looks a hot mess
Cool ,,,I think you should dismantle all,,have a big coffee and reassemble, yes cable lengths look like something I would do,,bit overkill,it's hard though not having bits to use,,we make do with what we have,I think you'll get thereI forgot to plug the left stick in and tested it.. Let's just say I made a good attempt at landing without the left stick and some how put it down without damage. Landed upside down
