Signal Loss
Hi!
Hope the masses can help me understand a challenge I sometimes get....
When I fly to maximum altitude (straight up from take off) I seem to lose control of the drone and it hits failsafe mode (currently set to land rather than RTH) - what's odd about this is that I can still control the gimbal but no directional control is possible.
Once it's landed I have to power on and power off the drone to be able to get signal back - I can then fly as if nothing had happened?
Any thoughts?
May be the orientation of you antenna and what are you calling maximum altitude?
Sorry - probably should have said that I have the altitude ceiling set at the UK maximum of 400ft.
I usually have the antenna pointing straight out from the remote.
The bit I don't really understand is that when I have no control with the "sticks" for horizontal or vertical control I can still use the gimbal tilt - surely all the controls are just part of the same data stream?
Cheers
C.
intertronixlabel
