Where do I get one of them?For profit needs a 333 exemption and a licensed pilot
Geese!!! That's too much! Are there any penalties for not having a pilot license?the pilot license however will cost you 4-10k depending on how fast you learn and how quick you want to get it done.
A pilot license will be a requirement in your approved 333 exemption. So, you will not be able to use your exemption without it.Are there any penalties for not having a pilot license?
Are there penalties for not having those?A pilot license will be a requirement in your approved 333 exemption. So, you will not be able to use your exemption without it.
You cannot fly for profit without a 333 exemption (and following the requirements within). Doing so would be illegal.Are there penalties for not having those?
I like to fly high, I will be recording for realtors so I would need a really good aerial shotYou cannot use the FAA UAS registration when flying for commercial purposes. Instead, you must register each aircraft and get an N number for each aircraft. In most cases, you don't need a COA when flying below 200 feet.
I just don't think I can spend a couple thousand on a pilot licenseYou cannot fly for profit without a 333 exemption (and following the requirements within). Doing so would be illegal.
Then, you should not fly commercially.I just don't think I can spend a couple thousand on a pilot license
:/ So if I am just flying at my house do I need to register the drone? And will you walk me through the process?In most cases, 200 feet is probably too high for taking video/photos of homes.
