https://www.youtube.com/watch?v=DHSQRjK ... e=youtu.be
Can anybody tell me with the settings in SimpleBGC to help the shaking on my vision?
Awfullynicefella said:Still waiting on mine to arrive. Did you get the power lead and how easy has it been to fit/set up?
lardaz95 said:Looks like a rather windy day, could that be part of the problem?
amkorp said:The constant slight vibrations in the video seems to be pointing at the dampers as the issue.
Do you have the damper protectors installed? If you do, then try tightening (if they are loose) or loosen them (if they are too tight)
That will probably solve the vibration issue.
Awfullynicefella said:Tizzle,
Is it a case of just fitting the gamble or do you have to do any software stuff?
rfernandez said:You have the same issue i did when yawing the camera stays tilted. that is because the IMU is not sitting in a vertical position in the slot the Remedy: Is to take a piece of paper fold it and fit it behind the IMU to get it in a vertical position and do a test flight. if is good and no roll showing on the video when you yaw. then use a little dap of hot glue on two sides of the IMU careful with putting too much that goes in the board.
rfernandez said:on this video https://www.youtube.com/watch?v=cDbE6326nsU as you yaw to the left look a the scenery towards the houses is tilted to the left.
