SD MINI PROBLEM
Kansas City Area
While inserting a new mini card into the P3S camera slot, things went Murphy on me. The card went in but I still showed on the DJI GO that the camera had no storage. Further investigation showed there was no card in the slot??? Bottom line the card went into the slot bypassing the card cage and just slipped into the camera body. You could even hear it rattling around inside the camera body.
So, the only fix was to open the back panel of the camera with a TORX driver, size T-6, lift the printed circuit board out of the way and retrieve the mini card. As an aside, I will be carrying the TORX driver with me to check the tightness of the four screws on that back panel as I found one very lose when taking it off. Still a novice and the learning is coming fast and furious.
Lucas_rc_pilot
