Can I use the Samsung Galaxy tab s2 with the Phantom pro4 controller?
Sent from my SM-N920V using PhantomPilots mobile app
Yes.Can I use the Samsung Galaxy tab s2 with the Phantom pro4 controller?
No problem. You should be happy with this choice. I have quite a few hours logged and have only had one recent issue in very cold weather, which I believe would have been with ANY tablet. The S2 is a workhorse.Awesome & nice setup. Thanks for the feedback bc i didnt want iOS Apple wanted to stick with Android i like the external storage for sd cards it gives you.
And it's OK with litchi?No problem. You should be happy with this choice. I have quite a few hours logged and have only had one recent issue in very cold weather, which I believe would have been with ANY tablet. The S2 is a workhorse.
Yepp, that's the key. Get it out and test away while you're within that return policy. The few S2 owners out here have all seemed pretty happy with their decisions over the past year. It performed flawlessly with my P3P and, so far, has worked very well with the P4P. I've experienced pretty low latency when their was not sources of high interference nearby. Having available 5.8Ghz now is a huge plus in the signal department. You never know when people have directional WiFi transmitters mounted outside of their house to shoot out to the lake (yeah, that happened...)After tryg so many other tablets to no avail i finally feel optimistic & have a sense of hope that this S2 gonna work for me. Verizon did tell me i have 14days to turn it in with no restocking fee if im not oleased with it
I have been using a Galaxy tab A and it worked fine except for a lack of screen sensitivity.And the answer is, fine.
I use a Galaxy S2 9.7" commercially with all of my A/C and it performs very well. As with any Android device running any of these flight apps, make sure you close everything else running in the background. I keep this tablet dedicated for flying. It still features one of the best/brightest tablet screens available and has plenty of horsepower for these apps. I'm waiting on the bigger Crystal Sky monitor to become available once any early bugs are worked-out. Until then, I'm very pleased with the performance of this tablet and the big screen real estate.View attachment 75468
With DJI Go 4 on the newer Tab S2 (mine is SM-T813) - I have experienced it not recognizing the USB connection. Enable Developer mode and then via the developer menu, set USB to RNDIS (no need for USB debugging), then reconnect. Mine changes back and forth sometimes - but always seems to default to MTP, and the DJI GO 4 app does not recognize it in that mode.I have been using a Galaxy tab A and it worked fine except for a lack of screen sensitivity.
I have just bought a Galaxy S2 9.7 and I cannot for the life of me get it to connect to DJI Go 4. The drone is connected to the controller and there is a green quick flash(2) from the drone, so that appears to be working ok. I can also start the motors using the controller. There is just no connection between the tab and the controller.
Am I missing something really obvious whilst changing tabs?
Regards, John.
Thank you for that info. My tab is the same SM-T813, it didn't quite work out exactly. I did find another answer though on Youtube (andy.davin ) and that was to power off the tab, switch on the drone and the controller, then power on the tab. All working fine.With DJI Go 4 on the newer Tab S2 (mine is SM-T813) - I have experienced it not recognizing the USB connection. Enable Developer mode and then via the developer menu, set USB to RNDIS (no need for USB debugging), then reconnect. Mine changes back and forth sometimes - but always seems to default to MTP, and the DJI GO 4 app does not recognize it in that mode.
Got my S2 this evening and up feeling so fustrated trying to get it to connect to Go or Litchi. I do e my homework & changed the usb bebugging to ON etc. Anyone willing to help me it will be greatly appreciated. Thank
