RTH altitude
I have a phantom 1.1.1. It is my understanding that it has the same NAZA controller as the Phantom 2. If that is the case, why can't I specify a RTH altitude for the Phantom 1.1.1 as the Phantom 2 users can? Is this just locked down to promote purchasing the Phantom 2?
Thanks!
As I understand if you takeoff and reset your home point in the air, you can add to the normal 20 meter return altitude. Is this what you want?
Monte55 said:
As I understand if you takeoff and reset your home point in the air, you can add to the normal 30 meter return altitude. Is this what you want?
I am more or less just trying to make sure Im not just overlooking something in the NAZA Assistant. I called DJI and did not get a very clear answer from them. It seems to me if they have the same NAZA M in them, they would be capable of doing the same things....
I do see your point and think it would accomplish what I want. Just thought it would be nice to be able to simply specify the RTH altitude in assistant.
