SlackerATX said:
DKDarkness said:
Thanks. Looks like they're using the 12.3 volts from the jack to power the BaseCam.
Be carefull. Wires from camera plus are so small. Thay CANNOT handle lot of current (mA, not Voltage)...
They already must power up camera. They are already too small !!!! When i put full throttle, camera stop to record !
If you add 200-400 mA for gimbal, you will get voltage drop. And problem @ FC200...
Advice is to take power on main plate, PLACING a FUSE !!!! don't forget it , 1A would do the trick. If you got a problem in fight, gimbal will stop, your P2V not !
