I think Keri's idea of having a dedicated customer service person would be an ideal situation especially if they are from here and they can relay the problems quickly and get responses quickly to issues like yours.
Geert said:
tedw123 said:What is the best FOV setting to reduce fisheye and where is it in settings?
Sent from my SPH-L720 using Tapatalk
DKDarkness said:tedw123 said:What is the best FOV setting to reduce fisheye and where is it in settings?
Reducing FoV on the FC200 drastically reduces image quality. The setting is found on the right, where you adjust movie resolution (Screen with different "width") You can reduce fisheye some by running the files through GoPros free editing software. http://gopro.com/software-app/gopro-stu ... t-software
dbcch said:Ugh, I hate it for the manufacturer (RotorPixel), after today's news. I would guess the pre-order list will get sorted out pretty quick now!
Speaking of the P2V+ of course.
FSJ Guy said:Why? The price is about the same as the P2V + RP and the camera is still the same craptastic quality. No real upgrade there, even though they had the chance. :- /
Why do you say that? The video is still 1920 x 1080, regardless of what FOV setting you use. The main difference is where it samples those 1920 pixels - from across the entire 4384-pixel sensor width, or from just the middle portion of the sensor.DKDarkness said:Reducing FoV on the FC200 drastically reduces image quality.
jimre said:Why do you say that? The video is still 1920 x 1080, regardless of what FOV setting you use. The main difference is where it samples those 1920 pixels - from across the entire 4384-pixel sensor width, or from just the middle portion of the sensor.DKDarkness said:Reducing FoV on the FC200 drastically reduces image quality.
dbcch said:At $1299 retail for the P2V+, your math doesn't quite add up. Also, the FPV and control ranges have doubled and the camera has a wider field of view. Also, apparently no reduction in flight time with the DJI setup, unlike RP.
Maybe you mistakenly saw the $2k price briefly listed by some unscrupulous Amazon seller?
