Hi everyone, I was filming a surf session 3 days ago with my Phantom 3 pro,I lost control of it 3 metre from the surface,it went straight down to about 2 metre. I searched for it 20 minutes,still couldn't find it.so I swam to the shore and replay my activity logg on the map,so I took two points from the hills and aligned them to get a fix bearing to the reef where it went down which was about 150m out.I used the marks/bearing and swam a straight line out.I was lucky to have found it,it had snagged seaweed. I unplugged the battery and swam as quickly to the shore,there was a construction site nearby I found a barrel of fresh water and I completely submerged and shook it for 10 minutes so to kill as much salt.As I got home I filled up my bath tub with fresh water and gave it another bath for 1 hour,smoke started to come out of the battery so i safely disposes of it. I opened the phantom to bits and dried it with my air compressor,then let it to dry out the whole night with my table fan.The next day I went to buy WD 40 and sprayed the whole thing,all the circuit boards also including gimble+camera,the whole thing striped. I let it do its work,then blew compressed air to try and remove as much wd40 as I can.I noticed there was a blue liquid coming off the circuit board I imagine that is the waterproofing paint they put to seal the boards.On Monday I'm going to get circuit cleaner and spray the whole thing again just to remove the residue left from the WD 40.I'll let her dry out for a week and power her up and see the damage.There were no visible damage anywhere apart from the battery connector.I just hope nothings shorted out,any advice please?
You should have used distilled water as tap water as chemical as well. The WD 40 should have been left in the can.
