Removable prop guards
Hi I had a p2 with prop guards and found them very useful
I now have a p3 and the dji hard shell case
I would like to be able to quickly add prop guards. What is best available that would fit in case once removed if you get my drift
Reactions: brianb87
The Summitlink product leverages all 4 motor mount screws. This might provide the additional support/stiffness to avoid the dreaded Phantom cracking.
Is it possible to keep the tension string on the prop guards or the fact you have to slide in the guards you end up with a slack string
