Really need help on a firmware issue
Columbus, Ohio USA
I downloaded the latest firmware edition and I am required to install the Phantom Default configuration parameters which is a zip file on their website.
No matter what I seem to do, I cannot open the zip file after downloading Winzip.
Does any one have the exe. file they could post or send me. I would be very grateful for that.
Chuck
New member
Chuck
New member
If you haven't installed the update yet. What I did, I hooked up my Phantom to the computer and did screen captures of the areas that I needed to ensure I put in the same settings once the update was done. I found that much easier and everything is working fine now. I didn't find many changes from what I remember. Good Luck!
Thank you, Fangs. I have downloaded the firmware update, and I want to make sure that the Phantom will fly right. I see in Tools that I can set default, but will that take care of my problem, and finish the procedure? What else do I need to do, if anything?
Chuck
Newbie in Columbus
Chuck
Newbie in Columbus
Maybe your download was corrupted.
Here's the unzipped default params file. Use Naza Assistant to load. :)
http://sdrv.ms/1cyNhfm
Do not fly after you reset to default in Assistant. You need to load the Phantom default params file first.
sansuciboy1
