RC video in/signal out antenna ports
Can sum one confirm witch antenna inside the remote were the two plug into the board witch is video in and witch one is control out ?
I'm fairly certain since my amp lights up and works only on the antenna port on the right and next to #4 . And the one on left must be control antenna port
Sent from my XT1585 using PhantomPilots mobile app
All i know is that the left(as looking from your pic) is for the right antenna & the right is for the left antenna.antenna cable directions.jpg
not sure if this helps because i'm not certain of inward or outward flow but this is the correct connection.
good luck
Does it really matters which side is which?
They're both 5.8ghz aren't they?
Scav8tor
