RC Broken
Hello, I'm from Brazil and I just joined the forum and bought a used Phantom 2 (No. P330Z) it came with two controls one broken (DJ6) and I was able to stop with the drone and another in good condition (SR6) and I was unable to stop with the drone, how do I know if the latter is compatible? And how do I know which models I can buy?
Reactions: RodPad and GFields
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
Check DJI's website
Reactions: RodPad
Thanks! But the DJI website only has information from the Phantom 3 onwards.
I know nothing about the p2 but couple pilots here have them and probably got some better info but I got curious and had look at DJI download center, link below .there's a compatibility list there too..Could only see this android version and totally unsure what one users to fly these nowdays. Couple of models in the p2 range which I added as screenshot for reference
Reactions: RodPad
Good luck, from Florida USA. You've got quite the dinosaur there but hopefully one of the ol guys here will be able to help. Amazed the batteries are still operational. Anyways, don't spend much if any money on the old bird, they're not worth it.
Reactions: IANZONE and RodPad
@IANZONE ,
Geese the info you find and post!!
@fernandohm
Its a Phantom 2?
Not the other versions?
I would point you here.
What did you pay for this and two controls?
Pictures of every thing with in each shot would be great.
BTW. :rolleyes:
Welcome to the forum!! 👍👌
Rod..
Reactions: IANZONE
Remote controls for your bird are the DJ6 or the NDJ6 (with gimball wheel tilt). Not 100% sure about the SR6, but think that should work also (may need to change receiver option in Phantom assistant software).
If its the P330z its the Phantom 2, in which case the DJ6 is the correct controller, the SR6 is for the phantom 1.1.1, both should work fine however, you would need to calibrate the controllers to the quad as the stick range may be slighty different from controller to controller hence the inability to stop the motors.
To do this you would need to download the software for the quad and controller and then calibrate the controllers.
This is my collection of Phantom software its just a collection of links to my google drive in an easy to use format
and here is a video showing how to calibrate the controller
